Is there any tips on changing this before I start?
First of all.....go to Lowes, Home Depot, Ace, etc. and purchase about 4 or 5 feet of 3/8" ID vinyl tubing.
I began at the water separator at the rear of the truck. I located the water in fuel sensor connector and disconnected it (generally it is "clipped" / fastened to the frame near the separator). Cut a long enough section of vinyl tubing that will easily droop down into a drain pain or old milk jug or the like. I then opened the drain valve and I used a metal band-style oil filter wrench to loosen the separator, turning it about two or three complete turns. If you do this, you'll ensure that your entire right arm and armpit will not be ultimately soaked in #2 diesel fuel. I then removed the WIF sensor. I'm not sure what size wrench is technically required to remove it; I know a 30 mm was too small and I was in a pinch and gently removed it with a pair of channel lock pliers.
Here's a pic of the WIF sensor removed.
Water separator o-ring assortment. The larger one is for the base at the head. The smaller one is replaced at the WIF sensor.
New water separator...note how it was dropped at some point in time as the base where the WIF attaches is crooked. The WIF screwed in with zero problems. I coated the O-rings with a small amount of diesel fuel.
I then replaced the underhood fuel filter. You'll need a 1 & 1/8" six point socket, and a selection of short extension and a long extension.....and a universal swivel joint helps. If this is the first canister fuel filter change, be prepared for it to be super tight....just like the factory oil filter. I ended up using a section of pipe to break the lid loose on my '13 and my '14. I also used a short piece of garden hose that slipped over the clear drain hose on the underhood fuel filter. I opened up the drain and let it drain into a 1 gallon jug. Remove the cap, remove the old filter, replace the new filter, coat the new o-ring with engine oil, and snug down the cap. Now's the perfect time to replace that section of short drain hose with a longer section so those periodic drainings won't get #2 diesel all over your front axle.
Pic of old fuel filter.....looks hardly used compared to an 8000 mile interval on my previous 2007.5 RAM 3500 Megacab. The EVIC said I was at 18% remaining. I reset the fuel filter life to 100%.
For priming, I went back to the water separator and opened the drain valve until fuel was present. I closed the rear drain valve. I cycled the ignition key on four times. It did start on the 4th cycle. As always, I checked for leaks and had my wonderful wife take it for a short drive.
