Finally a warm day so I decided to change the filters. It went pretty much as described. I opened the rear water drain , I did not loosen the seperator while on the vehicle and I did get a small fuel bath when I loosened the filter. Next time I will loosen the deperator or filter so some air will get in and that should avoid that. Nothing was overly tightened.
Getting the front filter open was a little tougher but once it is loosened the change is easy.
I am a little confused on the starting/priming procedure. On my 99 I could bump the key and the pump fuel pump would run. On the 13 (tradesman has a key) bumping the key makes the starter run until you shut the key off. After 2 tries and no start I tried just moving the key to on waiting a bit and doing it again. After doing that 3 times it started right up.
The evic reset by just holding the reset button a couple seconds. I was showing 7% left at 11300 miles, mostly towing a light 5000 lb trailer. I was hoping for a little more mileage
than that It reset to 100% but I just checked it again after moving around the driveway, 0 miles and it says 99%. Sure wish I knew what it measures.
Next time will go much faster.
How do you go about bumping the starter on a keyless system to prime the filters ? Or do you just hit the start and let it cycle through over and over until it starts ? Sorry task a dumb question, I am at 9% on my filter and by the weekend I will probably have to take care of it and want to be sure to do it correctly. At the tall cost of filters I am holding off as long as possible
