fuel gauge question?
Turbo Barking?
Amusing story....
sorry, i know ive read this before, but does anyone else having problems with the fuel gauge? our 2001. 5 6 spd hos both seem to have a mind of their own as far as readings are concerned. mine stays on full for about 200 miles, then drops like a rock. the other truck shows low fuel light and tone while still above a 1\4 tank showing.
Mine is weird too. Mine indicated 1/8th tank remaining last night and the low fuel light came on. Then today, I filled up and it took 27 gallons.
And this for a 35 gal tank.
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate 4. 10 USGear OD, Rickson 19. 5 Wheels, Edge EZ, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
It seems like all of our trucks are like this... bugged the bejesus out of me... So I dropped my tank, and checked the float level, and found it to be about 2 3/4 in. off the bottom... So I modified (bent), the stainless float rod so that is was only 3/4 in. off the bottom... now when the needle rides on empty, and the lil' dinger go's off, I have about 2-3 gallons left. . works for me. . we're not idiots, I watch the fuel guage, almost as much as the rear view mirrow, so it's unlikley I'll run out of fuel... . Yes, I know the fuel is also there to cool the pump...
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
My last truck, a 98 2500 gasser, did the same as yours, didn't move until 200 miles then dropped like a rock. This one seems suprisingly accurate, so far.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
sounds like something we'll just have to get used to. if this is the only problem that ive had so far i can live with it compared to some of the stuff that ive read on the ford and gm diesel boards. the low level light and tone should come on with 5 to 6 gallons of fuel remaining, and this a very handy thing to have when driving a diesel truck.
I have had my sending unit replaced a 1/2 dozen times. The Service Manager said that dodge is having a lot of proplems with the diesel sending units, no so bad with the gas units.
Do most of you guys with problems have diesel, if so dodge may replace if for you. they have replaced mine twice after the warranty ran out.
1998. 5, 2500, SLT, 24V, 4X4, Auto, 4. 10 towing 35ft. 5er
On Order due May 1. 3500, SLT+, Green/Tan, HO, 6 speed, 4X4, 4. 10, towing package, camper package, E-brakes.
