Engine/Transmission (1994 - 1998) Fuel plate recommendation
Engine/Transmission (1998.5 - 2002) Pyrometer reading high temp
2nd Gen Non-Engine/Transmission 2nd Gen Straight Pipe - Yea or Nay
I really appreciate all the input from everybody! I ended up going with the Afc Live stage 2 ,and the 450 hp ki and the 450 hp kit ! Basically it's the Afc Live with fThis kit includes:
AFC LIVE stage 2
AFC LIVE MAX TRAVEL KIT & 40 PSI SPRING
Bosch 5 X.012 INJECTORS
055 DELIVERY VALVES
DELIVERY VALVE SOCKET
Hopefully this will be a good set up I'm probably going to wait and do the injectors and delivery valves until after I can upgrade the turbo I'm super excited :) and as far as the 5 inch exhaust goes I'm thinking I'm going to like it a lot I've always straight piped all my diesels and every time I get on the throttle The little kid inside me smiles :)
Coopertop;
Whats the"40 psi spring" in your signature, surly not the heaveyer valve spring-which should be 60#?
After reading the "other post" and description of the box, must be a AFC spring, right?
