2nd Gen Non-Engine/Transmission Fuel Pump
Engine/Transmission (1994 - 1998) Thump! ... Nothing.
2nd Gen Non-Engine/Transmission Rear Leaf Spring
Had fuel and EGT gauges moved from dash to pillar mount on 25th. The light does not work and my gauge is reading 10lbs pressure and never had before moving the gauge. I pulled the gauge out and the leads were so short they came off the back of the gauge. I have a Westach fuel gauge and need the connection so I can hook back up when I get the wires pulled out far enough. Could it have been connected wrong and cause the gauge to read wrong. Put 170,000 miles on original pump and have only 30,000 on this pump which I purchased from Cummins. Would appreciate any help I can get on the connection.
!999 Red Dually, 5 speed manual,Straight PIped,B&D exhaust brake, Edge Easy. In bed auxillary fuel tank,fifth wheel hitch. fifth wheel tail gate
2005 34. 5 Hitchhiker fifth wheel
