Nick, thanks for the part number....same number as the 180 degree Napa currently in my truck with the Horton EC450 fan clutch that will only activate today when I turn it on manually, even on this HOT day here in the Midwest! Horton is set-up to automatically turn-on at 192 and off at 185 which is where the 180 degree thermostat is fully open. The 180 degree thermostat will start to open at 160 and be fully open at 185. Usually settles in right at 180 on most days....even winter. But the Horton fan clutch is completely deactivated when not operating.....only on or off with Horton. You know how the OEM fan clutch operates! The Napa 180 has good flow when fully open and my truck usually holds 185 without using the Horton fan when towing long grades if I can keep the truck in 5th (1:1) gear and at 50 mph or higher on a hot day. The Horton cools the temperature and rapidly when it is activated!When you are older like me (and you) you sometimes find things that don't make sense, that actually work Lol...and if not, I have spent $23 (includes 20% off) Plus I saved my old one if I need it this winter, kinda like a short sleeve shirt for summer and a long sleeve for winter. If it don't help at all, I will post it.
Michael, the #THM 375180
When I spoke with the retired Cummins engineer on the CUMMINS 800 number tech line years ago soon after getting my Dodge/Cummins he was very emphatic about ISB engine temperature and I remember him stating...."don't operate the engine over 195 degrees". The Horton EC450 has always kept it at 192 or lower and it usually runs around 180 and fluctuates between 180 and 185 with the Napa 180 degree thermostat.
Hope it helps to keep temps under control.
Thanks for the part # and keep us posted.
Michael
