Getting ready (finally!) to do the gauge install on my truck. Think I'll be going with the Di Pricols (Boost, EGT, FP) from Genos. I've read up as much as I can about it in the forums, but I have a couple of questions.
1) I was planning on getting the boost pressure from the plug on the side of the engine. As I understand, I'll need a fitting to reduce from 3/4" NPT to 1/8" NPT. Those of you who've gotten this setup from Genos--is the fitting included with the gauge? I'm not too familiar with plumbing (I don't even know what NPT stands for... ), so is this something I can just walk into Home Depot and ask for?
2) For the fuel pressure--I know the '99s are different from later models. Lack of a schrader test port, as I recall. Is there a way to mount the sending unit directly to the fittings on the fuel filter (it's the bottom-loading version, not the drop-in of later models)? Do I need one of those tapped banjos?
3) Finally, as far as tapping the manifold for the thermocouple goes--is there anything in particular to watch for? You guys have already convinced me to mount pre-turbo, and remove the turbo. I've never tapped a pipe before. Do I just drill the hole and screw the (1/8" NPT) tap in, letting it do its magic?
I appreciate any info you guys can give me. I think I've got a basic handle on it, but I figured I'd ask the guys that know. Also, keep in mind you're talking to an engineer here, so keep it simple, please--I can do orbit determination for the space station, but I'm still working on my 'useful' skills here, and I need you guys to help keep me out of trouble in the meantime.
Thanks, all.
--Ty
Thanks, all.
--Ty
