Engine/Transmission (1998.5 - 2002) Gauges - What's normal
Engine/Transmission (1994 - 1998) Trans lock up
Engine/Transmission (1994 - 1998) How do YOU clean YOUR K&N?
for everyone adding gauges that can learn from those who have:
What are normal readings for:
Boost
Trans. temp
EGT (pre-turbo)
EGT (post turbo)
Fuel pressure:
Idle
WOT unloaded
for an UNMODIFIED 24v 2nd Gen. ?
and then
BOMBs AWAY !
Well I don't know if it is normal but here are my guage readings
FP WOT 12psi
cruise 14-15psi
Idle 18-19psi
EGT Varies but doesn't ever go above 1100 It sets about 700 cruising at 70-75 down the freeway on level land.
Boost varies also but you won't (shouldn't) see boost on a stock 24v'er above twenty.
That about covers it from my end
Good luck and happy BOMB'ing
Mark
Boost-----18 before EZ--now about 30
Trans temp----125-150 no load
engine temp---190 (hope to lower that soon with 180 themo.
EGT-Pre----60-70 about 750
EGT-Post--60-70 about 600
FP--idle about 10
WOT about 5--stealer says 7--his tow and new pumps!!
Hope this helps... ... . R, J. B.
