Gauges
Auto transmission Fluid Change Questions
AFE filters
Got my '92 W350 home and now I need to start upgrading it.
I have a Autometer tach on my '89 and am not real happy with it. Since a factory setup is hard to find what is everyone using, isspro? I would like a setup that uses the stock damper pickup and not triggerd by the altenator.
Also are there any two gauge dash pods out there for a first gen? I'm using an a pillar mount for the pyro and boost in my '89 but beleive a dash mount would be nicer.
Thanks.
Jeff
Jeff - Lots of options out there, but check out my readers rigs for some ideas.
I'm also working on an Autometer tach setup that does not use the alternator. It get's plugged into a column-mount pod for a 2nd gen rig. It's hard to explain but if it works it'll be the clickest thing since oversized turbo's.
- Sam
I have Isspro gages and I'm pretty happy with them. No pods for me though... I have the tach on the column, and boost and pyro mounted in the dummy panels where the A/C vents would be if I had it. I like the more stealth look... . part of the strategy... helps with the surprise factor and I need the edge ;)
Jay
