Geno's Cab Fresh Filter
Best electrical tap?
Autometer Pyro
Installing cab fresh
Originally posted by illflem
15 minutes if you drag it out.
Bill, do I have to remove the wipers? looks like the frame has a large hole in each section for the wiper shaft to go thru it.
just curious.
Phil
Re: Installing cab fresh
No, you don't need to remove the wipers, throw it up there and you will see. I did not even use a drill, but if I was not so Lazy it would have made it easer.
just curious.
Phil
Phil, I was set to pull the wipers off till I actually put the filters up there and saw how they worked. Wouldn't have drilled holes either except that the screws kept on tipping over when I tried to self tap them. :)
