Geno's Muffler Eliminator
Water Spots
air filter confusion
After listening to more than a couple Dodge Diesels running without mufflers, I ordered the Muffler Eliminator kit from Geno’s. (I love that sound!) Although I truly expect no impact (forgive my naiveté – I’m new to this) other than that sweet diesel song, is there anything I need to look out for performance-wise, warranty-wise or otherwise? I think I’d enjoy the ME if no higher power (the local Pfuzz or The Wife) raises no serious objections. Since I will rarely be pulling hard, I don’t think the noise will be too overpowering in the cab. Anyone have a two-penny response/comment? Thanx!
2000 2500 QC 4X4 Sport, black 3. 54 auto, every option but Cab Lights - and ALL the stencils are coming off... Black steel brush/grille guard, black steel bed rails, black Westin nerfs. And more to come...
I would also recommend the K&N replacement air filter. I think it's better that the OEM and you can hear your turbo spool up. Some people say it helps fuel economy and hp, also. Nothing clearly proves that point as far as I know. I do know it comes standard in many of the upgrade kits (like Banks), so they obviosly think it is an improvement over stock.
where do you get this eliminator kit and how much? I looked in the Geno's Garage link on the TDR homepage and didn't find any muffler eliminator kit, as always thanks for the help
y2k QC 24V ISB SLT 4X4 SWB 4. 10 LSD AUTO
The muffler eliminator Kit is part# 0079-ME Kit-$69. 00. A tip from a guy that has used it. The factory exhaust pipes do NOT come apart very easy. I wrestled with mine for hours. The clamps on my exhaust were over tightened so the pipes were crimped together. I had to get mine RED HOT before I could seperate them. Had a local garage do it. Didnt have a hot enough torch..... Just worth mensioning.
1994 Dodge Ram SLT Cummins 5 speed 4x4, XLerator airfilter,Optima red top batteries,Turbo&Exhaust blanket,Magnaguard rear diff cover,Edelbrock IAS shocks,muffler removed,Borgeson steering shaft,Trailmaster steering stabilizers,Rancho upper & lower links,Polyurethane sway bar bushings,Skyjacker 2" leveling springs(front),Fabritech Stage II Traction Bars,Denman Coyote A/P LT305/85R16(36" Tall) tires on Stock Dodge Chrome 16x6. 5 wheels,Bushwacker Street Flares,Back-off saftey brake light,Bugflector II bug shield, Diamond Blue 9004 Headlight Bulbs (65 watts low 100 watts high),Royal Purple ,Amsoil& Red line lubes throughout.
1970 Plymouth Cuda (under construction)
1968 Hurst HEMI® Dart , Nah its just a screen name ;-)
Your cab noise will increase, at least mine did. The neighbors will not invite you to parties from here on. But I get the coolest turbo whistle at the end of the tailpipe. Sounds like the teapot has reached the proper temperature while idleing. Your performance will not change. The two reasons to remove it IMHO, it will reduce egt, in particular when towing, and it may reduce back pressure on the turbo.
When I installed mine, I recall hack sawing the connection to the resonator to get it apart.
It will be significantly LOUDER.
98. 5,24v,3/4 ton,2wd,lsd,5sp
blue box hp enhancement
HVAC speaks the truth! His was the loudest rig at the Bay Area Ram Runners meeting last Friday. Some guy commented "wow, that's loud" when hvac pulled up.
We'll see how it stacks up the the 4" exhaust I am installing next week.
Craig
I enjoy being noticed. Good thing I had the "Blue Box" in low range! If you install that 4" exhaust system, I will be forced to take counter measures. I'm thinking dual 5" stacks? It may be necessary to add propane afterburners for greater affect at night.
Loud 'n Proud
'Kinda makes me wonder now if I should just go with the 4" exhaust versus the ME. I checked out Ted Janetty's site. Saw the kit, but saw no pricing. (I'd probably have to buy the kit and install it myself; I can't see making out to SoCal for the mechanic that was recommeneded earlier on this board (to install a 4" system), and I'm not yet aware of any good ones in the Tulsa area. ) And I certainly see the K&N filter in the near future. From the posts it almost seems that the K&N needs to be standard equipment... 'Listening, DC?
I agree about the K&N standard. What kind of black brush guard and where are you getting it? I have the black Westin nerfs and can tell they look great and work great.
'Gone Dodge on the brush/grill guard and bed rails - both black powder-coat (see page 28 of the 2000 Ram catalog). After running chrome Westins on my current '97 CC stroker, I couldn't think of putting anything else but Westin black powder coats on the new one - but I want EVERYTHING to be black this time...
