Borg Box is Installed
Got the Borg box on the truck yesterday.
Wow. :-laf
If anything it is a little too powerful, there is basically zero resistance when turning the wheel. It took a few miles to get used to it, it is so smooth you think the shaft must have come apart because you don't feel ANY resistance. It made the whole truck feel better, I love that feeling when they feel like new.
My steering was bad, bad, bad, the herding of the truck down the road was getting old. I didn't realize how tiring it was doing that. I did three hours of driving last night, it feels GOOD.
Had a couple problems during the install and some info.
The box has an adapter on it where the steering shaft connects to it. you can easily take this off to grind a flat for the stock shaft. But why would you? This set up is so worth the money, buy the shaft. Being the curious type, I took mine off just to see the shaft coming out of the steering box, nothing exciting but the adapter comes off, take it off if you are going to grind on it.
I have a frame repair right at the gear box from where I broke a steering box and it then tore the remaining two bolts right out of the frame, it was a really rough road. #@$%! well it was more like a goat trail. Anyway the repair consists of a 1/4 plate on the outside of the frame and three heavy duty sleeves that run through the frame. I had stock gear box bolts holding my old steering box on the truck as there was plenty of thread on them even with the extra 1/4" plate. well the new box has some stand offs attached to the body. So when the box is in place the threads are an extra 1/4" away, this also had an effect on the BD steering stabilizer which I'll get to in a minute. There was enough thread to get me down to the hardware store for some new bolts, 13mm if anyone is wondering. this shouldn't be a problem for most people.
I'll be calling Geno's today to let them know that the BD stabilizer and the Borg box do not work together. I had the BD stabilizer installed already, took it off to get the Borg box on, went to put it back on and even with the adjustment built into the BD stabilizer it didn't align properly, I had to grind off the flat tab where it attaches to the pitman arm shaft and weld it back on so it would center up with the center of the pitman arm bolt. I moved it a 1/2", it is now perfectly centered on the pitman arm bolt and the slots which are supposed to be for this adjustment are now perfectly centered on the bolts where it attaches to the frame.
This box sits closer to the Engine, mine is touching a transmission cooling line, I'll have to get under there this weekend and see what I can do about that.
If you buy the BD steering stablizer I hope you know a welder or are patient enough to send the thing back to BD to have it modified. The said part is that it had such a nice paint job on it before I started grinding and welding on it.
I would have been pretty upset if I didn't know how to weld.
At the end of the day I had a huge smile though, it is so smooth, it is fun instead of scary to drive again.
I'll get some pics up when I get a chance.
