Got the locker installed.
My window sticks??
Wheel center caps won't come off!
I picked up the truck just now and so far I lovet. It does ratchet a bit in a hard turn. The tech said with the long bed it will not be as noticeable as in a shortbed. Some of the cluthces did show signs of wear and everything went as planned. He did test drive it and said "man what a truck,wish I had one".
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
It is the lock-right from power-trax. Try www.powertrax.com
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, lock-right locker, 3. 54 gears, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Did it fit the anti-spin housing or did you have to get an open housing?
Does anybody have a complete 3. 54 anti spin carrier they pulled out and want to get rid of?
'94 3500 4x4, 210,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"I am my own performance station"
Had to put an open carrier in and then went with the locker.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, lock-right locker, 3. 54 gears,ez edge, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Okie, I just got an e-mail a couple days ago from Powertrax saying that they didn't have anything currently available for our rear differentials. They said they had products for the front Dana 60 but nothing yet for the Dana 80 LSD. What model number did you get? Thanks.
98. 5 2500, 24v, 5 speed, QC, 4x4, 4. 10 LSD, short bed, Line-X liner, tow package, camper suspension, Westin nerfs, camper shell, TST PowerMax Competition, 275 RVs, Psychotty air, HX-40, 4" straight pipe exhaust, ProComp A/T 305/70/R16s, EGT/Boost pillar gauges, Grover air horns... Love my Cummins, no love for Dodge
Okie-Go, I put a lock-right in my 96. Don't expect it to last more than a month or so. Mine would not lock both sides,from the moment I put it in. Two weeks ago I was testing, after doing a little tuning of the engine, and was somewhat surprised to have both sides unlock during a 4000 rpm burnout. Quite a disconcerting feeling,to say the least. Upon tear down, I found I could unlock both sides simply by turning the tires by hand. It seems the springs are not Strong enough for the torque our engines put out. I fixed mine by fabricating spacers to fit between the halves of the locker, of course it won't unlock at all now.
96 2500 4x4 5spd 3. 54 grs, #10 TST plate(plate and housing slid all the way forward), AFC spring kit(light spring), Holset H2E-17cm turbo, CUSTOM 4" exhaust With 5" stacks, Custom air induction system With twin K&N RE-0880 air filters, Banks Twin Ram intake manifold, ATS three piece exhaust manifold, TST guages, 370HP injectors, 3800 rpm governor spring kit, BD's High Flow delivery valves, "Accidently" modified fueling curve, Slightly advanced timing(17. 5deg. ) Modified valve lash, 60# valve springs,Powershot 2000 propane injection system, Mcleod dual disc clutch(street), Lockright lockers front and rear, Rancho traction bars, 315-75R16 Durango AT's on American Eagle 16x8 wheels for street use, 33-12. 50-16. 5 Denman Groundhawgs on 16. 5x9. 75 American Eagle wheels for pulling, Linex liner and rocker panels, soon to come, Piers' modified HX35-16cm and H2E-17cm dual turbo setup
With all that power on a burn out I'm not a bit surprised it tore up. I plan on mine coming in handy in mud and wet grass. I have no plans to spin my tires on pavement. I am glad you got it fixed.
True,what had to be done was take out the lsd. Then put in an open carrier and add the locker to that. It can be done,but that is the way it has to be done.
