Got the mud flaps how do I install them?
Air compressors
How hot does your EGT read when not hauling
I bought the Dodge/Cummins mud flaps (from the Cummins store) for my truck. How should I install them? Should I use screws or bolts? I don't want them to fall off because I didn't install them correctly.
Any help would be appreciated.
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
red1ton,
I used black screws for my Dodge factory flaps. I think they were provided. They held on the '95 truck until I removed them to install them on the Y2K.
I did dab a bit of silicone sealant on each one to prevent rust at the unpainted edge of each hole I drilled.
Loren
2000 Quad Cab, 4x4, short bed, six-speed: U. S. Gear exhaust brake, MileMarker Select Drive viscous coupling, Velvet-Ride spring shackles, Painless Wiring circuit box, Optima yellow-top batteries, Super-Glide 5th wheel hitch, Reese folding ball gooseneck hitch, Drawtite front hitch receiver, Tekonsha Sentinel brake controller, Westin nerf bars, Clarion sound system
1995 Standard Cab, 4x4, long bed, automatic: Firestone Ride-Rite air springs, torque converter lock-up switch, 4" cat-back exhaust, Reese 20K 5th wheel hitch, Reese gooseneck hitch, Hayes Micro Control trailer brake controller, 100 gallon bed-mounted fuel tank with 12 volt electric pump & fill nozzle, Swiss Cap fiberglass cap
Red1ton
If its the rear flaps that you are talking about as seen by your sig. its the big heavy dually flaps. Little screws just wont cut it, you have to use bolts. Thats what i used and they are very secure,no chance of coming loose.
may be late for you, but for a future reader,
FRONT: selftapping stainless hexheads, with large-outer-diameter stainless washers... run-em in with the cordless Makita!. . (may need to remove tire to get good angle for the drill motor. I did #ad
) Makes them look "no nonsense"
REAR: utilize the holes that the plastic fenderwell punch pins poke thru, but replace them with 1/4" stainless carriage bolts (roundheads towards tire, and nut lockwashered on underneath the truckbed...
