Grabber not grabbing
Which 16 x 8 rim for a 97?
Need Amsoil Dealer
I love my PM 3 but am having trouble with the Grabber. It worked fine after install for about 3 months and then began to lose contact with the pump wire. I stop and fiddle with it and it works awile, then acts up again. I secured the grabber to the bottom of the throttle bracket and that seemed to help some but it still fails at some of the worst times. Anyone having a similar problem? I really do not want to scotchlok that wire.
Have you thought of using Auto motive Goop its sold in auto stores and most dept stores ,Its strong and will hold most things after a cure time use small dab and build up to thick blob when you wan't to remove it can be removed by peeling it off takes time to remove all if you do not cover splice with plastic or tape first Keeps out of wire easy to remove . I use it to hold and water proof splice wire , Fore those that have problems with plugs turning out a blob next to and on one side of nut will keep in place . The stuff can and is used in hundreds of ways . Ron in Louisville KY stick with it.
