Grease Drying-up on Ball
I used to use Mystic JT-6 Multi- Purpose, High Temp Grease on the towing ball until I had a ball loosen up on a trip from Phoenix to Terre Haute, IN. for a Scheid Diesel Extravaganza event. I pulled over in TH & lifted the trailer tongue to tighten the ball. I was surprised to notice that the grease had dried up & turned into a black, clay like substance.
After this experience, I went to an RV dealer & bought a 4 oz. container of Towpower by Reese, hitch ball lube, part #58117. It says on the jar that it is:
*White grease
*Odorless
*Non-toxic
*Will Not Break Down
*Reduces Friction
*Superior Lubricant
and, Made in USA.
I've used this product for a number of years, now, and it seems to work much better than the grease I was using. I've never noticed the black, dry clay-like substance on the ball since I changed.
Have any of you noticed this with your grease? If so, you may want to try the Towpower product. However, the white grease (probably the same product) in the areosol can may do just as well & be easier to apply.
Thanks for the recommendation of brake cleaner for cleaning up the ball. I've been using WD-40 & it does not do a great job but, is better than nothing.
Joe F.
