Engine/Transmission (1998.5 - 2002) grid heater wires and corrosion....
Engine/Transmission (1998.5 - 2002) Glacier
Engine/Transmission (1994 - 1998) Fuel plates - which one for me?
a while back while i had the intake horn off for some reason, well, after putting it all back together, i forgot to reconnect the two wires that go to the grid heater. they were touching other metal parts and when i started the truck they arced. there were some scortch marks on the injector lines and part of the battery cable blew out. Now i've noticed that the two nuts on top of the grid heater are rusted. This has been about a year ago, i reconnected the wires and had no other issues. Now, my batteries are bad, but i suspect that it is not related. they are the oem batteries from '02. I do however have quite a bit of corrosion on the passenger side battery. My questions are: do I need to replace the grid heater wires? Why are the nuts rusting? Do i need to replace the battery cables? I'm just wondering if what happened has led to some electrical issues. Thanks for the help.
also, is there a part number for the two wires that connect from the grid heater to the inner wheel well? I went to the dodge dealer and they couldn't find em. Could these be made using the appropriate gauge wire just as easily?
If you need wires, just make them up. Use Type-3 marine grade (tinned) cable, tinned lugs with solder plugs and adhesive heat shrink tubing. I'm not sure of the gauge, probably 6 or maybe 4 AWG.
You should make sure the battery cables on both batteries are clean and coated with a corrosion inhibitor. I use Corrosion-X and/or Electro Guard (anti-corrosive dielectric grease). A little corrosion will cut down on the charge getting to/from your batteries. Use a little dielectric grease on the grid heater cables too. Remember, iron + water + air = rust, a little grease or paint will help.
I still have the original OEM batteries on my 01. 5. They will probably last through the coming summer, no problem.
