Originally posted by kaptn
to to all behind me. #1
Originally posted by Jim Fulmer
Ok were going to change the subject here, now that were all on board with the Water/Meth those of you that dyno or tow we need some data to back this all up, so lets say by Jan 1, 2004 we start a post about the end results, I won't jump on it with my old setup of 200 degrees reduction, 55 degrees of air temp drop at the hat or 107 hp in Valet (made 124 with a smaller pump) both with Twins but I will give data on the new set of Twins as there is allot more air, also I will be going to a Custom intercooler (fingers crossed) that will bolt into our trucks so I may not need the EGT reduction but I will want the HP gain because I've lost my mind.
Jim
Originally posted by BigYellowIron
is it to late to get on the list?
I think I would like one.
Adam
Originally posted by sticks
Man this list is getting long. I am going to chop down the list to only those members that have not ordered (as in you posted and gloated about you order position), or provided the required info.
Looks like jrandol will have his in this weekend, and I plan on being there for the birth. It's will just be embarrassing if he manages to break an input/output shaft on the way to the dyno. Poor transmission just was not built with 600hp in mind.
Yes, it is nice having a properly functioning VP44 now. No codes, and I can definitely feel the difference in performance with the new one.
