GSI Sound Stop Experience??
Rancho RS9000 shock upgrade offer - expires end of this month
GPS/Delorme street atlas 7.0
Anybody have any firsthand experience with the Great Southern Insulation Sound Stop Product? I am interested in applying some noise reduction material to the inside of my truck cab to take some of the road and engine noise out. I have reviewed most of the other sound suppression threads on the board. What I want to know is if anyone has used this particular product and what the results were? Is there another product you would recommend that you do have experience with?
I am also considering the dynamat stuff, but it is a bit pricey.
Joe
Joe,
Greg Long (Lsfarm), our resident Noize Nazi, has tried I think
about every sound supression product known to man on
his truck, and I have shared a ton of emails with him of this
subject. He recommends the SoundStop "super foam" very
highly.
I have installed a layer of the 1/2" foam on the floor and 2 layers
on the back cab wall, also on the rear quad cab doors and just
ordered more that will go on the main doors. So far, I really like it.
It is pretty easy to handle and install, and seems to work very
well for me.
Tom
I used the 1/2" 'Super Foam' from GSI and have been very pleased. This product is easy to work with and performs as advertised. I wanted to go with their 1/2" closed cell foam on the floor in case of spills or leaks, but felt it was too expensive (about $2 more per square ft). GSI was very helpful, knew what I was after, and was eager to provide the 15% discount when I mentioned the TDR. I will finish my project (door panels) when I get a break in the weather. With the floor, back wall, and ext. cab inner walls done, sound levels are greatly diminished.
Joe, I also have used the 1/2" GSI Super Foam and I am pleased with the results. GSI also sells something similar to Dynamat, but its cheaper. Its called "GSI Sound Damping Sheet". It is 1/16 of an inch thick. KL
Noise reduction Thread
Hi JRodgers, check out this thread below, kind of the granddaddy of the noise reduction threads.
There are a bunch of photos in it. The GSI foam is the best product I've found and tested so far. There might be other comparable or better products, but not that I have used. There are some other recent noise reduction threads using new and different products.
My best results are using lead sheet first then covering it with GSI soundstop foam
https://www.turbodieselregister.com/forums/showthread.php?threadid=40821&highlight=Noise+Reduction
Greg L. The Noise Nazi
