Has anyone found good replacements?
BullyDog Injectors - Dyno #'s???
Just BOMBED stereo!
Has anyone been able to locate urethane suspension bushings to replace the OEM bushings. I think this might help tighten up things a bit.
Thanks Andy
I know the sway bar bushings are available.
The upper & lower Contol arms for a 4x4 are available with poly bushed ends. The bushings will not go into the OE links.
Swaybar bushings would help but I'm hoping to find bushings for the links also. I think if I replaced them all I would hotice a big difference.
I have looked into this as well. Skyjacker offers a kit for 1500's. That's it as far as I have found. You may be able to use some of the 1500 package in our situation but you would have to e-mail them to find out.
RED 98 3500 12v 4x4 Quad Cab SLT Larimie, 4"BD exhaust and brake, triple mount AutoMeter Ultra Lights, govenor spring kit, delivery valves, 370 B injectors, 332-700 camplate, 16 cm2, new carter lift pump,Mag-Hytec diff,Horton Fan Clutch, NorthWest Fear This mudflaps,custom dynamic timed pump by AWD,Linex,Tonneau cover w/ bike rack over the bed,Billet grill and bumpers inserts, Eclipse w/center seat sub enclosure and remote alarm.
80 Porsche 911 SC Turbo Look Porsche Club Racing Trackcar, Totally Bombed
Cannondale Killer V 900 SL
This is Energy Suspension's transmission mount. They only make 2 styles. Anybody feel like measuring to see if one of these would fit our auto or standard trans trucks? I don't feel like laying in the snow. #ad
[This message has been edited by HEMI®Dart (edited 01-27-2001). ]
Energy has everything, I ordered the sway bar bushings(greasable) and the end link buschings from them (red) to match the Skyjacker lift. You can get all the body buschings from them as well. http://www.energysuspension.com/
1997 Dodge Ram 2500 HD / Club Cab, Cummins Turbo Diesel (silencer ring removed), 4. 5" Skyjacker Double Flex suspension lift, 36x14. 5"x16. 5" Ground Hawg radial tires on 16. 5x9. 75 Weld Super Singles, dual steering stabilizer, 4. 10 precision gears, 33-tooth Speedo gear, Rhino liner, Grizzly double bent nerf bars, Bushwhacker flares, Kanduco grill insert, Confer super skid axle truss, DT Trac-bar, Moog tie rod system, Fabritech Traction bars, Energy sway bar bushings and end links. Truck Pic's
