Have a Ghost in my truck need help fast!
Motor oil in the fuel? yuk
K & N RE-0880 & 25-0880 hookup?
OK heres one for ya that I have never experienced. today while driving home my door locks all of a sudden would periodically unlock themselves. I did not think much of it that maybe I bumped it with my hand. Well tonight I walk out and the lights in my truck are on, so I hit the lock button on the transmitter and it locked; not two seconds later it unlocked again. I tried both door switches and both of my key fobs but no success; it would keep unlcoking. So I took both of my key fobs and located them about 300 feet away so they would not be "seen by the truck thinking maybe I had a stuck button or something but no success, keeps unlocking. It sounds like the Centeral Timer is sending out the unlcok signla and in some cases holding it for a couple of seconds. Anyone have any ideas? I pulled the power door lock fuse and that killed the problem along with my interior lights and of course the security will not arm. Anyone with any good ideas please let me know this is a problem I want to resolve fast. Also just a note it has been raining here so not sure where water could get in and do this but it is a factor.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
Thanks for the info checked it and it does not fully apply but is worth a shot, the unusual part is that it just started after 26,500 miles. Also update, I pulled the fuse to the door locks and reinstalled it when I left and well it still happened but unudually it did not do it as often, also noticed that the over 15 MPH locking was not occuring.
well pulled the battery cables and well you guessed it as of right now the whole thing is fine, so I guess to the dealer for a new CT as mine fell into the catagory time frame for the TSB, again thanks
hey mike- tell taz to knock it off- If taz is haunted the ghost might listen-- #ad
maybe utc is testing their newest secret weapon- you drive by their test site on the way home-- #ad
coarse have you changed any electronic magnetic fields which could be on taz's frequency- key pass, radio, cell phone ect. many key passes put out a signal- my wife's would set off a securety alarm at a local department store- something to think about--- see ya tues---- bub
well thought that the battery reset fixed the problem, well it did for about 10 minutes. Now instead of it wanting to unlock the doors it is locking them instead, going to run to the dealer first thing before I leave.
You have a real interesting problem. Please keep us informed about what's happening. I don't care for the security system, everytime I go under to change the oil my truck starts beeping at me. I'm guessing you may have a faulty sensor somewhere. It probably only takes one to mess it up, and those sensors are all over and under the truck.
The problem is the truck knows you are allowing HVAC #ad
into it sat so its doing all sorts of weird things before it happens we all know what type of influence he is on most trucks #ad
see you guys this weekend
2001. 5 ETH/DEE DD3's EZ HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, more to come
[This message has been edited by wiz1 (edited 01-13-2001). ]
There is a TSB out on the problem or one like it. [TSB 00 08-26-00].
A friend just had the same problems, doors lock/unlock and cab lights come on. It happens with the truck running or shut off.
I tried to paste the site here with the TSB but it won't take.
Thanks Mike for bringing this to my attention. I was doing just fine until I read your post. #ad
Since I fall into the range of the TSB, should I get the Central Timer replaced even though I do not experience any of these syptoms? I just hate to go to the dealer unless I have to.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins ETH/DEE, SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Autometer Ultra-Lite (electric fuel pressure, vacuum), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, SmittyBilt Outland Sport Bumper Gaurd, 2-LO kit, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
Ghost in the truck,,Sounds like you better call Art Bell,,He'll dial you in on a person to exercise the spirits from your truck,,Or is their something your not telling us here,mmmmmmmm... ... ... ... . #ad
98, Flame Red, Quad Cab, 2500, 4x4, 5spd, Autometer and Cyberdyne gauges,Edelbrock Performer IAS shocks,TST#10 plate,16cm housing, B-D Exhaust Brake,Timing Advanced,K&N,Totally Amsoiled,Cat Muffler and Silencer ring ALL M. I. A. ,A BOMBING IN THE PROCESS!!
Check out my post from 3 days ago "Power door locks went nuts" i am having the exact same problem right now, since wensday. All i can do is pull the fuse
I don't know that I would do it just because but if ti does happen at least you know wha to do. Problem with pulling the fuse for the guys with the Security package is in some cases it will not allow the truck to start if you pulled the fuse at the wrong time.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake w/ DTT Smart Controller, Power Edge, Edge EZ, Grover Air Horns, P. S. High Idler, RV 275 Injectors.
Ram-Taz
"Christine", Stephen King's possessed 1958 Plymouth Fury, has come back as a RAM.
Order a supply of black shirts and black jeans.
I'd be very careful!
