Engine/Transmission (1994 - 1998) Head stud torque @ gasket thickness ?s
2nd Gen Non-Engine/Transmission wierd buzz-vibrations
Engine/Transmission (1998.5 - 2002) pyro tap ats
Got my head resurfaced today, they took off eleven thousandths.
Is a ten over head gasket going to be ok as far as piston/valve clearances? This motor does see 4000 rpm frequently.
Next question-I have the A-1 head studs from Piers. What should I be torqueing these to? Also, for reference, what alloy are these made out of and what is the approx. tensile?
What is the best way to retorque? I have read both: following cummins torque sequence, and torquing in bolt rows. Do I do the 3-step deal on retorque or just break loose and torque to final step?
One last thing: I expect to see about 45 psi max max boost, not sure about drive pressure, but how high can I go with timing without losing another headgasket?
Truck Specs: 98 12v, 370's, #0, 4k GSK, Piers cam, HX35/40-16, Snow Water/Meth
Thanks,
Matt
You could do a . 010 over or a . 020 it's up to you and that will clear most cams.
Do a line torque
A1 studs are just fine!
Timing at 17 or so, maybe towards 20 with an O-ring, you do run Water/Meth
I would bet drive pressure would be 60 at 45 psi of boost... ... this is a guess!
Jim
