The 1k dollar studs are commonly referred to as "625's". They are also a direct swap in but are even stronger than the standard. The studs that require drilling are 14mm rather than the stock 12mm.
-Scott
yes im in NC and the PbyP is a Crack on olle poole After Falling out with him like 80% of people around here I had an anonymous friend (Jack) take my head to be o ringed so he wouldn't sabotage it I then couldn't resist advertising to him that I had done it so I put that into my sig. Im not gona say you won't build a long lasting relationship with him just saying most don't and go to farmboys. They Do deck the head some during the oring process its a simple thing and you can buy the tool to cut the grooves for like $280 but its worth the expirience that a shop has to get it right. 625 studs are overkill unless its a full blown pro puller with a twin set that can push like 100psi +.
I know this is an old post but I figured I would chime in anyway. I got the ARP studs that fit and did one at a time, left the stock head gasket. Put it on the dyno a week ago. Boost went up to 54 with no problems. As a rule 50 is the max I go with stock head gasket but I feel like I can do 60 with no problems. Putting in 150 injectors this weekend.
Put my twins on about a month back. Now I need more fuel, hence the 150 injecotrs. I was real dissapointed with my dyno numbers; only 363 HP and 850 Ftlbs of torque. I am shootin for 500 and I think the injectors should do it. The injection pump I have on is a High Output model and with the 150 FASS I hope to have enough fuel to catch up with the air I am putting out with the BD twins.
Time is always the issue, but the hardest part of what I have done was the head studs so you have the worst behind you. Putting the twins on was pretty straight forward once all the pieces of the puzzle came togehter. Good luck and have fun putting on the twins.
