Details here: TDR Privileges
Is there a vacuum modulator on a 92 that would cause the heat or vent settings to blow out the defroster vents and if so where is it and how much crap do I have to dissemble to change it out?
My '94 will intermittently do the same thing. It only does it when I'm going slow, like parking, or hooking up to the trailer. When it does it the brakes barely work. I had a new vacuum pump put in, and checked all under the hood for a vacuum leak and couldn't find anything. But it still does it, but doesn't do it all the time. What could it be?
It is hard to find a vacuum leak because when the engine is running you can't hear it and when the engine is off there is not enough storage to still have some if the pump is not running. I would guess your booster is leaking.
