2nd Gen Non-Engine/Transmission Heater-A/C control shot?
Engine/Transmission (1994 - 1998) 47RH Transmission Problem
Engine/Transmission (1998.5 - 2002) Transmission Line Leaking
hey guys, I turned my A/C on yesterday on the way home and i can only get the air to blow through the defrost vents no matter where i set my switch. . I dont get any air blowing at my feet or my dash panels... any ideas?
First confirm you still have vacuum-no leaks in the system then once confirmed ck at the vacuum actuator by your rt foot near the skinney pedal
one of my rubber boots that connects to a T fell off on my weatherstripping under the hood. . that was my vacuum leak. 10 second fix. I also secured the vacuum line on the back of the hood weatherstrip with zipties. thanks for the help!!
In a similar vein, my temp control does not work. Switching to A/C will give coolish air, but otherwise, my temp is fixed regardless of dial position. I will be searching around here for possible answers, but thought I would give a quick ask when I saw this.
First post BTW.
Tim
02 2500 SB, SB clutch, NV4500 (rebuilt), FASS, Edge Comp
I just fixed that one myself go to the website heatertreater. That part goes into the actuator. I did not calibrate it as the directions said. But I put the new piece in and the dial works.
