Guys,
I need some help locating a PN# and/or the actual replacement part for the dash in my 97. I need the sub-frame assembly. Not sure what else to call it, its the large plastic piece that basically everything on and in the dash mounts to. I "think" it is item 4 on the drawing. Mine is shot. Breaks when you look at it, age and I assume heat have done it in. I have glued, screwed, patched and so on, until there's just very little left to work with.
I'm currently having the entire AC system replaced and now is a good time to replace this dead dash part!
ANY help would be appreciated!! if you have a better diagram with actual part numbers that would help A LOT.
Thanks,
Thanks,
