TGVET
The friction material form the clutch packs will just drop into the pan, what can get out anyway. What stays in the clutch packs will stay and clog the vents.
TC clutch friction material will go thru the cooler.
If you are seeing flakes of friction material its only a matter of time. The glue that holds the friction material on is water soluble. As it deteriorates it just gets messier.
Rebuilding now before a major failure is advisable. Just an FYI, a new direct drum for a 48RE is over $600 retail. Save the hard parts as much as possible.
What is the drum ?
