I just drilled and taped the 1/4" hole for the EGT probe. I was going to disconnect the exhaust manifold from the turbo but that looked like quite a chore. I drilled the hole on the rear vertical down section of the exhaust manifold. I used lots of grease and had a shop vac rigged up with a hose right at the hole. I still got some metal filings down in the inside. I spent about 30 minutes fishing around with a magnet. The last 10 minutes came up with nothing. The problem is that I don't know how far filings will go since the hole is in a vertical section that goes right to the turbo and you are bending the magnet at 90 degrees?
I have a air compresser, would it do any good to poke a nozzle in the 1/4" and try to blow anything that might be left through the turbo? Problem is some of the valves are open so I would be blowing air back through some cylinders. I also wonder about taping the exhaust pipe shut and starting the engine? I don't think a 1/4" hole is big enough for exhaust gases to go through? Is there something else I could remove to get a look at the turbo? Like the exhaust elbow or would that also be a chore? Whats a new turbo cost?
Any ideas?
Any ideas?
