Well the old DieNasty (1988 Dodge Dynasty, 3. 0, auto with app 275,000 miles) saga continues. In the last few weeks I've replaced the master cylinder (2 times), and the fuel pump. Thought I had this baby ready to give another few months of trouble free commuting.
BUUUTTT, I should know better. Now it dies after a few minutes of normal driving, after a bit of cranking (I can hear the fuel pump running a few seconds when cranking) it'll restart run for a minute or two, then die.
In the shop it'll run forever if I rev it up to 3000 rpm or so, but let it drop down to 1500/2000 rpm and it starts acting like it's running out of fuel and dies.
I replaced the tps, no help. It has a new fuel filter along with the new pump.
I'm thinking something electronic is causing the fuel to shut down. If the pump or fuel pressure regulator were bad, I would not expect it to run at 3k rpm.
Any suggestion's are welcome at this point.
Thanks,
RJR
Thanks,
RJR
