Hesitant start
Aisin downshift ?
Fuel filter life index not resetting
I have always thought I was blessed because I now have 30K miles on my truck after just 18 months without any of the issues others on this site have had. The only two issues I've had was the cruise control button became intermittent which the dealer fixed by replacing the steering wheel panel and the radio randomly changes channels by itself which can't be duplicated. Now that I only have 6k more miles of warrant left an issue has happened 3 times in the last couple of weeks. When I go to start the truck the engine starts to turn over but only rotates for a split second almost as if the batteries were dead. Turn the key off and try again and it start rights up. Once it was when I was starting the vehicle for the first time of the day but the other two was after driving and then shutting it off for 10 minutes for so. Anybody else had this happen? Would that throw a code that the dealer could see? I'd like to get this fixed before the warranty expires.
Thanks.......Don
I have had it happen several times (about 10-12 times in 3+ years). But i actually have to remove the key and open the door to let everything power down. And then get back in and start it. Battery terminals look good to me. I can't show it to the dealer, because i can never predict when it will do it.
This is most likely your cause. It is kind of long, but we had to make it as simple as possible because most technicians didn't understand the theory and just started replacing parts. The cause is voltage drop, so as was mentioned clean the connections, including the battery terminals. it was written for gas (NGC controller) but your truck also uses the T41 circuit for neutral/park position.
Click No-Start is an unofficial name of a condition that is possible on some Chrysler brand vehicles. The name “Click, No-Start” comes from the click sound that is sometimes present and reported when the vehicle does not start. Due to variations between vehicles however, the click sound is not always present, even when the no start condition is present.
The condition described here occurs when a ground offset between the Powertrain Control Module (PCM) ground and the engine/transmission ground exceeds a certain threshold. The ground offset is typically caused by loose or corroded attachment of the negative ground cables or minor degradation of the negative ground cables. The condition does not necessarily occur because of added resistance at one specific place but may be a result of stack up of resistance at multiple places on the vehicle.
On Chrysler brand vehicles where the PCM also incorporates the Transmission Control Module (TCM) the PCM monitors the transmission gear position. This is accomplished by a Transmission Range Sensor (TRS) located inside the transmission. The TRS is attached to the transmission valve body. The TRS connects to the PCM with four sense circuits. The PCM supplies voltage to the four sense circuits and monitors the voltage. Based on the gear position selected, the TRS grounds the individual sense circuits. Depending on which circuit is high (12 volts) and which circuit is low (0 volts) the PCM determines the actual transmission gear position selected. For starting the vehicle, the transmission must be in either the Park or Neutral position.
As a requirement of starting the PCM performs an addition verification to determine Park or Neutral gear position using the T41 range sensor circuit. To verify Park or Neutral and allow starting, the PCM must see a low state (low voltage) on the T41 circuit. The threshold for this low state is considered to be 1.9 volts however the actual threshold could be as low as 1.4 volts. This means if the voltage on the T41 circuit exceeds 1.4-1.9 volts the PCM will sense the vehicle is not in Park or Neutral and therefore not allow starting.
When added resistance is present in the battery cables, some of the available battery voltage drops proportionately at each point where resistance is present. This voltage drop condition will increase as the current load on the battery cables increases. When the driver attempts to start the vehicle the current load on the battery cables will be at its greatest. If resistance is present on the negative cables, the engine/transmission ground will have a voltage above that of battery negative. If this voltage offset exceeds the above mentioned threshold starting will not be permitted.
In most cases on vehicles that exhibit this condition the ground voltage offset will be below the threshold when the vehicle is at rest. This permits the PCM to see the Park/Neutral position. When the ignition is turned to the start position the starter begins engagement. The moment the starter begins to engage the current load on the battery cables also increases causing the ground voltage offset to exceed the threshold. This causes the PCM to sense the transmission is no longer in Park/Neutral and disallow the starting. This partial but interrupted engagement of the starter or starter solenoid is one of the sources for the click sound.
Proper diagnosis should include measuring the voltage on the T41 circuit. In most vehicles with an NGC PCM the T41 circuit is in cavity 27 of the PCM C4 connector (may be C3 pin 27 on RFE). Using the NGC breakout box place the positive lead of a DVOM to the T41 circuit. Connect the negative lead to the battery negative post. Monitor the voltage under the following conditions. Repeat the testing as necessary to get consistent results.
• Ignition On, engine not running, electrical loads turned on
• Ignition On, engine running, electrical loads turned on.
• Starting the vehicle.
It may be beneficial to use the min/max feature of the meter. If the meter reading exceeds 0.5 volts excessive voltage drops are present even if the vehicle starts. Service the vehicle grounds as necessary to reduce the measured value as low as possible. Less than 0.1 volts is preferred. Adding redundant grounds may be beneficial both for testing and for repair.
If the sensed voltage on the T41 circuit remains high and no excessive resistance can be detected anywhere on the battery ground cables this could indicate added resistance in the TRS contacts or circuits. If necessary, these should be closely inspected.
Thanks Sag2 for the detailed information. From what I gather from your explanation this "Click No-start" is what in years past was just a clicking noise when the brushes in the starter or the starter solenoid went bad and the starter wouldn't engage. My starter does engage and turn part of a revolution so I would think that would pretty well eliminate any of the sensors that determine the vehicle is in park. I'm off tomorrow so I'll check the battery connections first before taking it to the dealer. Thanks again to those that answered.......Don
Well not exactly. The click is from the ECM thinking the truck is in park/neutral. It allows the starter to engage. But the high amperage draw from the starter causes the high voltage drop across battery/T41 connections that have any excessive resistance and the truck thinks it is no longer in park. It immediately shuts down the starter solenoid driver. This all happens in a blink of the eye.
I apologize in advance for high-jacking the thread, but this sounds exactly like what I have had happening on an old 5000 Ford tractor for years and any help is appreciated. It does not have a *CM of any sort. We just got through putting a new battery, new starter / solenoid and battery ground cable grounded to the tractor body (not the starter housing where it mounts to the tractor) and the problem is still present. Any suggestions on this? I am at my wits end with it. It may start the first turn of the key, it may just click when you turn the key. Zero to several clicks later, it will turn over and start right up. You never know and cannot predict.
Sag2, thanks for the information. I have been searching forums for sometime to find an answer to this same problem. Mine does the same thing on occasion and I can get it started by placing a jumper between pins 30 and 87 on the starter relay. Do you think adding a larger ground cable down to the engine and frame would help with problem? I guess it couldn't hurt.
Thanks in advance.
It doesn't really need a bigger ground, it just needs a CLEAN ground. Passenger cars with the little battery cables could probably use a larger diameter cable.
