High Idle, 06 and Manual
Window won't seal
leak in cab
Wire Harness's, switches and headache's?? My 06 manual kicks into high idle (1000 rpms) when its cold out side, by itself without all the hassle. Does this switch allow the high idle to come on at anytime??
Hey Hercules130 do you have the part number on the cummins box for the whole kit?
2006 quadcab 3500LB,4x4 Kore Recon,Interco SS 35x10. 5x17,
A higher idle raises cylinder temperatures to help warm up the engine. And most pto pumps need the extra rpms for proper flow.
__________________
93 250 2wd xc 354 auto 264k
04. 5 3500 4wd cc dully 373 6-speed 87k
You can get the clutch switch from PacBrake, same switch used for their brake install. Most people have just pinned#22 of the rear connector with a short jumper wire and run it to ground on a nearby bolt. Works fine that way as long as you remember to set your parking brake, transmission in neutral, then set your cruise. It will idle up to 1500.
CD
