Ok this is a new one for me. Started today, oil pressure at least 10 psi higher than ever before.
Conditions, Outside temp in the morning startup 68 degrees, fleetguard oil filter, Rotella T6 15W40 (900 miles on oil change), Autometer mechanical oil pressure gauge. at startup idle 80psi (normal 70psi cold), 1800 rpms, pegs autometer gauge at 100 psi. Engine warms up everything is normal, 24psi at idle, 70 psi at 1900 rpm. motor runs like it should.
Startup after work 3pm out side temp 74 degrees, does the same thing. Checked oil, where it should be, color is correct.
140000 on motor rebuild, the oil cooler and bypass assembly and oil pump, new Cummins part at that time.
ok any ideas?
Kyle
ok any ideas?
Kyle
