Holding the Trip Button while Turning Key
Power steering fluid out cap
Terminal corrosion: Battery doomed?
Last night I was trying to retreive the number of hours on my 06, I held the Trip button while turning on the key, all kind of light came on in the guage panel, guages started moving and the odometer starting flashing codes and with each change of codes, the guages reset to another point. Didn't have a pen handy to right them down, but does anyone know what the display sequence means that are displayed??
Thanks in advance.
i know there is a way to test all the guages and dash lights, maybe thats what you did. It lets you look to see if any of the bulbs are blown out, i think.
That is the sequence to iniate the Cluster Diagnostics. I have posted the Cluster Diagnostic codes a few times, you might find them by searching.
I don't have them on this computer.
The display is a xx nn, and will finish with 00 00, where xx is the code and nn is the number of times key is sequenced since the code I think.
Here is a list I found on line.
INSTRUMENT CLUSTER FAILURE MESSAGE
Fault Code Description
01 Airbag warning indicator output circuit shorted.
02 Airbag warning indicator output circuit open.
03 ABS indicator output circuit shorted.
04 ABS indicator output circuit open.
05 MIL indicator output circuit shorted.
06 MIL indicator output circuit open.
07 Wait to start indicator circuit shorted.
08 Wait to start indicator circuit open.
0B BTSI output circuit shorted or open.
22 Headlamp switch input circuit shorted.
23 Headlamp switch input circuit open.
24 Turn hazard switch input circuit shorted.
25 Turn hazard swiitch inpot circuit open.
27 Courtesy/dome output circuit shorted or open.
28 Glovebox/map lamp output circuit shorted or open.
29 Cargo lamp output circuit shorted or open.
40 Wiper switch input circuit shorted.
41 Wiper switch input circuit open.
42 Wash/beam input circuit shorted.
60 Passenger door lock switch input circuit shorted.
61 Passenger door lock switch input circuit open.
62 Passenger door lock switch input circuit stuck.
63 Driver door lock switch input circuit shorted.
64 Driver door lock switch input circuit open.
65 Driver door lock switch input circuit stuck.
66 All door lock output circuit shorted to ground or voltage.
67 All door unlock output circuit shorted to ground or voltage.
68 Driver door unlock output circuit shorted to ground or voltage.
6C Driver cylinder lock switch input circuit shorted.
6E Driver cylinder lock switch input circuit stuck.
80 Incorrect odometer value found.
81 Remote radio switch input circuit high.
82 Remote radio switch stuck.
A0 Internal module FLASH memory checksum failure
A1 Internal module bootloader failure.
A3 Battery voltage open.
A5 TCCM messages not received.
A7 VIN checksum error.
A8 VIN previously stored.
A9 PCI bus internal failure.
AA PCM messages not received.
AB TCM messages not received.
AC ABS messages not received.
AD FCM messages not received.
AE ACM messages not received.
AF SKIM messages not received.
B0 RKE fob batteries low.
B1 RKE module communication link.
00 Done All Diagnostic Trouble Codes (DTC) have been displayed.
Retrieved from "http://wiki. dieseltruckresource.com/wiki/Computer_codes_C_Codes"
So then, how DO we retrieve hours? Thanks. Great info.
Engine hour retrieval on my '03. Not sure if it is the same on the later models.
With the engine shut off, turn the ignition to the run position. From the odometer reading (not trip meter), push and hold the button. The trip meter will show and about 5 seconds after that the hours will show. If you try this while the trip meter is showing, it will just reset the trip meter.
Jeff
Don't know about lifespan in hours, but I just checked my truck and it has 36366 miles with 1001 hours. 36. 33mph average. Turbo1Ton, thanks for the tip.
If I take my average mph and apply it to 350,000 miles it comes to 9,634 hours. I think 350,000 is the Cummins stated service life, or something like that.
I have 280,000km (174,000 miles) and 3400hrs (can't remember exaclty)
My sons 97 12V has 800,000km (500,000 miles)..... dosen't run much different now than when new and does not yet use oil.
I haven't checked my 2001 in quite a while, BUT IIRC 30 MPH is about average and 350K / 10,000 hours is about average design life, sounds like you are right on track.
SHG
