Installed the Genos Relocation kit today with a Holley Blue pump. Very easy install ran into no problems at all. Im only seeing 10psi at idle and around 7. 5psi at WOT with comp on 5X5. Why such low pressure at idle?
I had 2 holleys in a row with the same preess. your seeing. They also started dropping pressure after long tripsI got tired off that crap and got my A1000 and set reg. @18psi Now its rock solid! The walbro is also a good chioce. the inline pumps have fuel cooled and lubricated elec. motors.
What is an A1000?
Look in summit, in the fuel pump section. Its the round inline model. Aeromotive is the brand. I bench tested it before i installed to see if it would pump veg. oil. (the holley will not attempt to do that). The A1000 pumps anything, even motor oil, and still build way more pressure then we need. You need to run a regulator. Last summer i ran 75% veg oil, and i still mix it in when I get nice oil. Not much anymore. It will supply enough fuel for SERIOUS HORSEPOWER!
Thank you. Where did you mount it?
