Horepower Hungry?
Air Box Removal
Belt
Well I am! I have DD3's and The Edge Comp Box w/5" Exhaust. Now what can I get for more power and less EGTs. I know turbo but then What? Besides Propane or Nitrous Induction!
All HELP would be great for someone that is very power hungery.
One day Twins will be there But for now I need to get some answers for more power!
You could try larger injectors, steps 4 and 5 are available. I would swap out the HX35 first though, then go from there. Probably would be an even split if you added an HX40 and larger injectors over what you have now with the 3's as far as egt's go. Throw in a Pyscotty air system for good measure. The ETH doesn't like LPG so much, many have reported blown head gaskets when running propane with the ETH, though some have reported blowing only one and all is fine since the OEM gasket was replaced. I'm thinking of trying NOS, will probably wait until spring for that BOMB. I have no idea on what the Edge Comp. box performs on the ETH, other than I haven't heard any ETH owners complaining. I can say that I very seldom turn on the TST box, the HX40 coupled with the step 5's and the EZ are more than enough for daily driving.
Scott W.
have you seen????????
the aerial photos fro the space station showing the trails of jetliners crossing the United States ?
Well with all of these DD5's and Super Mental&reg injectors being installed on many Cummins TD's
We (as a group) will be next on the radar screen :eek:
**** Like Joe D said way back when, save those stock injectors for future use**** :confused: EPA :eek:
do you know...?
SBurton,
Have you run your truck on a dyno? ... or have you run it before and after at the track? I wonder what you've gained so far? I have an ETH also, and I'm trying to base my projected BOMBs on other owners experiences/experiments.
Thanks for sharing your info, hope someday I can pass on something beneficial to the members!
Galen
