Ok,
More info now on the exhaust system and rifling veins after the new AU flash... I went ahead and pulled all the veins out and ran the truck for a 40 mile round trip for a good enough run to get an idea of what is going on with the setup with just the OEM Down-pipe and the rest being straight pipe.
The truck lost alot of its performance. The turbo will just not dig into the incoming air charge and pump up the pressure. The fuel mileage on these tests I ran this afternoon and tonight was just with the overhead reading as I was not taking the time to fill up or any of that sort of thing. I do think the over head will be fine as a relative guage reading for now and I can use it to tell if an improvement takes place in fuel mileage. Not so much as what kind of fuel mileage I am getting
For that sort of thing I think most of us here know to hand figure that is the only way to know exactly what the MPG is!!!
Anyway, truck running at 68-69 throughout all the testing and using the cruise control to do that, same round trip each time I change the rifling veins and as close to being the same as I can make them. Was quite eye opening if you ask me!!!
Truck sounded a little better and more throaty with all the veins out, but the performance was way low suck guys. She was not a pooch but was not a go getter either. Fuel mileage was 12 MPG on the test run round trip, which is from my house through a little bit of town driving and some highway running and back to the house.
I then installed a rifling vein with 1. 875 full turns of the flighting. Now I hear the turbo hook up and dig into the air charge coming into the intake area and spinning the heck out of it through the tail pipe... Loud hissing sound for the lack of a better way to describe it.
The performance was hands down better also, along with a much improved fuel mileage on the 40 mile round trip. As I pulled in front of my shop door the mileage was coming on down a little more from the in town driving to the shop, but this time I was 18. 6 MPG...
So, very certain now its in getting the turbo to hook up with the incoming charge of air. Removing all the restrictive filters of the DPS system I ended up with a low suck performance wise and a fuel hungry honey LOL...
Was quite the show down I have been wanting to mess with and its been quite the learning lessons tonight as I finished up for the evening...
So next thing is we need to get the programmer guru's after us the software for this. Until that, this system I have allows me to run without the fear of the DPF getting all clogged up so much. Plus now I can add the fuel additives like the gray bottle powerservice and get the benny from it helping keep the fuel injectors cleaner and the fuel being sprayed better... Not to mention the fact that I have never had the overhead mileage guage never read 18 MPG unless I was to clear the reset button as I was going down hill and read what it was as I got near the bottom LOL...
So now I need some able testers whom have the straight pipe setup on their truck already and have also put all the sensors on the straight pipe setup they have... I know there was a few of you guys that have done this already.
If a few of you want to give one of these veins a try for me and let us all know how they run and fuel mileage, I will make a few and send them out. They will need to be installed as I will tell you of coarse, but for you guys that have the straight pipe setup already with all the tap points in place for the sensors, this added into your system won't be that hard at all.
I would ask to know what kind of elevation your running the truck, as well as what kind of temps your running in and if you have the new AU flash as well. I really would perfer to send these veins out to those running the AU flash as well...
At present I have ran these veins for over 10K miles and now with the new AU flash I got about 2K on that. This next week will be with just the one vein at 1. 875 turns also. I want to see just how this all acts now like this pulling the trailer, but at the point I am right now and at a 75-85 degree temps or hotter; this sucker runs pretty good...
