Guys,
The new AU flash was suppose to deal with the cooler by-pass valve standing open or at least the ECU thinks so. Mine and one other in the area here that this dealer works on. Only two this dealer has from what the tech told me.
There was suppose to be a few other small things addressed also, like help a little with fuel mileage and such.
Well this morning run was its first and the truck ran fine, but it maybe running in regen somewhat all the time as Courierdog mentioned his was. I will know more maybe tonight when I leave out again, but if I had to guess I would say its in regen, at least the very first stages of it.
Now this will be where it gets really tricky too, if my exhaust system lets the ECU think the filters are stopping up enough for a regen and its going into this all the time now as there is nothing for the regen to burn out, won't know for sure for a little while
Sure need some guages on this truck, but I keep holding out for the PMT system from Bullydog, but I am not going to be holding out much longer, and just get something else. To much time has already passed...
My work back ground, well I did pipeline construction and repair for more than a few years and all over the place. Plant work as well as over the well bore. So I know my way around plumbing stuff of all types and from small to really large, hot as well as really nasty cold also
I got out of that for the most part but not all together, and went to work for an Outboard motor company, some may know as OMC, they built Johnson and Evinrude outboard engines for boats, which I cut my teeth on those as a kid growing up on a lake in Texas. I had the lake right out the back door as a kid. So working on these motors is second nature for me...
OMC filed Chapter 11 on 12-22-00 and I went to work later on for the company that bought those motor lines and they had me working up north for a while and offered me a position at the Racine, WI. plant... It just never felt right and was not the right time for me to make a move like that I guess, as I refuzzed and came back home...
Right now I provide a hotshot service for a certain area around here, company I contract this route from is from the D/FW area. I usually run 2500 miles a week,at least that much and more some weeks. Keeps me busy to say the least.
My truck has never gotten the mileage I see being posted here either... I am not so sure about this new flash as I had my truck do a cough twice about 5 seconds apart on the way back this morning early. Not sure at all what that was about as it quite about as soon as it started and has not done so again.
Could have been poor fuel, but I doubt it really. If this was a two stroke outboard, it would be telling me the motor was way too lean when it done that and I would be fattening her up and quick too
Not knowing more about what they may have done with the timing on this latest map change, does have me asking if maybe the timing might be off??? I have just not ever had a diesel do something like this before, but it sure sounded lean and I felt a miss at the time this was all going on too...
Now changing the subject back to the topic at hand, I don't want to be blamed for hy-jacking the thread here LOL... One thing you guys do need to keep in mind here is that while my system has the truck running well up and until this morning, its not a straight pipe system per/say...
I do still have the OEM down pipe on so far as well as its got several rifling veins in strategic places that are acting somewhat restrictive. Nothing close to the stuff that was on this truck though LOL...
I am certain to have the software change needed to be able to run sure enough straight pipe setup will be best. But until that comes about, I had to see if I could fake the system out somewhat and get the DPF off the motor before it killed the turbo as well as the rest of this setup...
I also see a hugh thing with just how freakin' well the 6. 7 runs at 2250-2400... I sure would be curious to know just how well a truck like this with the 4. 10 gears would do. Sure seems to me to be the ticket, but with how wild mine has been from one day to the next through all this, who knows
