How do you disconnect the break controler plug from truck?
Please stop posting the truck taking out the bank!
Talon-USA Suspension
I want to replace the current break controler in my 2008 CC with a new one that has the "all in one connection" from the truck to the controler.
The current controler was spliced into the break controler 4-wire plug supplied by Dodge.
I have spent over two hours so far trying to disconnect the Dodge supplied plug from the connection under the dash board with no success.
Are these plugs from Dodge a "once pluged in, they are permanent"?
I see the "bump" on the side of the plug (driver side door side), that I have been trying to put a small flat blade screw driver into and lifting what I think is the snap connection, and try to pull the plug out, but it won't move no matter what.
Anyone ever have this problem -or- know the secreat trick of how to remove the controler plug?
You have to compress the little bump on the side, namely the little white part while pulling out on the plug. You have to push it into the side of the plug pretty hard. bg
