how do you turbo silencer ring?
U
Transmission cooler lines
Replacement of front cross joints?
Has anyone ever done a dyno test on their truck pre-removal and post-removal? I have to imagine that the increaed turbulence created at the turbo inlet after removing the silencer ring could have a negative impact on performance.
Who cares though - I removed my ring last week, and I like the sound! I wonder how loud that turbo would be with the Psychotty air filter system. Hmm.....
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger. Autometer EGT and Boost gauges with 2-gauge pillar coming soon!
http://www.rints.com/hammond for photos!
Take off the intake tube to the turbo. Get two screw drivers, one small and one a little larger with a long shank. You'll see a gap in a steel spring band about 3/8 inch inside the opening. Catch the end of the spring with the longer screw driver and lift it out of the groove and then stick the little driver in there so the spring can't slip back in. Now take the longer driver, get on the back side of the band and pop it out. Then remove the aluminum ring the band was holding in by simply taking your fingers and pulling it out. That's all it takes.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards, Lucerix X Mount Heated/Power Mirrors
Yeah there is a snap ring there you just need to pry that out, with 2 screw drivers and then the silencer ring will just fall out. Its sounds very cool!
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Raceing Exhaust, DTT TC & VB, EZ Box, Bosch 275 Injectors, Mag-Hytech transmission pan/Dana 70, K&N, 33" BFG AT'S... ... .....
As strange as it sounds, dont lose that ring or the locking clip that holds it in. If your turbo ever dies and you bring the truck in for warranty work, put the ring back in. They will probably try and say you "Modified" the turbo, which is BS but you know DC.
