Originally posted by Diesel Freak
I would try one, but the exhaust side is the wrong size (turbine, turbine housing, and outlet), and the turbo as a whole is too small for what I will be doing with it.
Originally posted by JaMan
McDowra: I've been real interested in this turbo also, You never said if you can get a TDR member discount, and is the 14cm wastegated a direct boltup, or does it need a hx40 downpipe and some changes for the wastgate assembly? Also what Hp range and max boost? Also it is listed w/o the housing do you replace it with your own hx35 housing?
Jared::
