How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
Replaced Heater Fan 47K... ... $340 warrenty would not cover it
Install DSS steering bar 48K
LIFT pump 50K... . replaced with FASS
Injector pump 51K Factory replaced
installed VA 53K
Lost Clutch 58K
I really like this truck just do not know why.
38000 miles. Just rebuilt the Vacuum pump. 2001 4x4 1 ton. 40,000 miles installed Fuel Pressure Gauge,Replaced Lift Pump,
Cow Catcher
Cracked Exhaust Manifold
4th Fuel Gauge Sending Unit
A/c Clutch
A/c Would Not Quit Opr And Would Freeze Up- Dlr Replaced Relay
Battery(s) 2yrs And 2 Mos
A/c - Htr Fan Comes On By Its Self Dlr Fixed But It Still Does It
4th Left Front Brake Pads
Catch Me If You Canhttps://www.turbodieselregister.com/forums/newreply.php?do=newreply
Bad Year
8/30/2004 3- transmission/ Fifth Gear 620,000
8/22/2004 1- TPS 618,000
8/18/2004 1- VP44 & 2- Lift Pump 617,000
7/13/2004 1- Throttle Cabel Assy. 603,000
7/8/2004 1- rear Crankshaft & RearTrannySeal 602,225
7/8/2004 1- Oil Pan & Oil Pickup Tube Gasket 602,225
7/8/2004 3- Clutch 602,225
4/4/2004 1- AC compressor&Clutch/Belt 567,000
3/24/2004 1- Rt Frt Wheel Hub Bearing Assy 561,833
2/5/2004 1- Clutch Master&Slave assy. 543,000
Oo.
So far -
Two clock springs
driver side butt burner works, but nowhere near like it should
vacuum pump oil seal began leaking early on, replaced at 41k under warranty :)
power steering pump seized up when vacuum pump was replaced, also under warranty :)
A/C evaporator at 3 1/2 yrs and 52K :(
Now at 54K and all is well, except for anticipating the LF/VP44 failures. :eek: Ya gotta love the 12v.
Mileage vs Failures
My 1999 2500 24v 4x4 six speed has 102000 mi. s .
So far ... shocks at 15K and 95K, steering shock @ 98K, thermostat @ 65K, lift pump and injection pump @ 99K. Still have original brake pads !
No other problems so far :D
Ed
lift pump 50k
air pressure sending unit
transmission rebuilt twice
vacuum pump
track bar
ball joints
vp44(replaced weak lift pump)
cam position sending unit
brakes out the nose
SHOULD OF KEPT MY CHEVY
57,000 miles on the 04, with absolutely no problems Oo.
However, the 99 had many problems in it's 97'000 mi. life. Just to name a few- track bar, radiator leak, 5th gear nut(twice), transmission toast at 94,000, exhaust loose & whistling, poor mileage, oil leak from transfer case. All repaired on the Monday built machine though.
57,700 miles with only sensor problems such as speed on Rear Diff, ABS, & Trans. My Dash Board is cracked up.
I got 235000 miles. Replaced a few lift pumps(cant remember mileage) crack exhaust manifold, drive the hell out of it and it runs like the day I bought it
128,870- one lift pump, two injector pumps, two clutchs, and one turbo( mistery bolt in air box while changing to k/n, no more friends in the shop) but still love it.
01. 5 2500 with 167,000, one lift pump, break job, new clutch at 124,000, apps, belt idler, rear trany seal and new tires.
James
Catch Me If You Can
My wife is telling me that I have to keep her (my Truck) till she (my Truck) reaches a million. I think she (my Truck) can do that. Oo.
