How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
2001 3500 213,000 miles,
3 lift pumps
1 transmission + converter Replaced with Goerend
Vacuum pump seals
Two rear drums & shoes
Two front rotors & pads
Transmission speed sensor
Front wheel bearings
Fuel gauge sending unit
Still runs like a raped ape. Would love a newer truck but when I read of all the troubles you guys have
I'm keeping my old '01
1999 2500
104,555 miles
May 4, 2000 15000 Transfer Pump
June 6, 2000 16122 New Fuel Sending Unit and Hitch Recall #872
June 26, 2000 16654 New Windshield and Replace Steering Column
September 18, 2000 19749 Dash Screws on top of Dash Tightened
January 19, 2001 23408 Headlight Switch Replacement
October 23, 2001 32219 Re-surface Rear Drums Adjust Brakes
September 20, 2001 33663 Intermediate Steering Shaft Replacement
November 30, 2001 33781 Debris in Blower Motor, Transfer Pump Replaced, TSB for Waterline Fitting Location, Rear Differential Service Pennzoil 80/90, Transfer Case Service Mopar ATF
January 29, 2002 35770 New Center Console
June 7, 2002 39066 Lower Steering Shaft Replacement
August 5, 2002 40953 Rear Axle Seals (both sides)
December 31, 2005 74947 New Ball Joints and Alignment
February 8, 2006 75398 Track Bar Installation
May 12, 2006 76790 Vacuum Pump Seals, Installation of Crank Case Ventilation Fleetguard Enviroguard Kit
December 22, 2007 79622 Cooling Flush, Upper Radiator Hose and Clamp, Lower Radiator Hose and Clamp, Cooling Thermostat
September 11, 2009 88495 New Batteries
October 11, 2010 Repaint Top of Cab and Top of Hood
June 1, 2011 92011 DSS Steering Stabilizer
June 22, 2011 92089 DSS New Solid Track Arm Kit
July 25, 2011 92101 Monroe Steering Stabilizer
August 24, 2012 94432 New Dash Installation
March 16,2013 96850 Sport Headlights, Sport Harness and reconditioned Fog Lights with Xpel Film
April 12, 2013 97420 Installation of Alpine CDA-9811 radio
April 16, 2013 97420 Rebuild Starter - Plunger and Contacts
June 8, 2013 98760 Install FRRP Fuel Pump
September 19, 2013 100400 Rebuild Starter - Plunger and Contacts
August 30, 2014 104300 Rancho Steering Stabilizer
Engine and running gear are great, everything else has been replaced.
Currently replacing MAP Sensor.
Update...
2001, took delivery in October 2000.... 62,000 miles as of October 2014.
Waiting for the chassis to rot away, leaving a sub-100k Cummins behind.
Well I guess I missed this thread for the last 13 years or so. My 01 is at 320,000. nothing major has gone wrong outside of a few lift pumps and a few vp44's. Other than that everything has been pretty much maintenance related. Ball joints x2 180k and 300k, rotors all around at 285k had a caliper stick and take one out so I went ahead a replaced them all, calipers all around see previous, ac compressor 310k, transfer case at 186k, DTT transmission 110k however original wasn't broken yet but wanted to do it on my time instead of in bfe, a map, iat, cps sensor at different times, a couple thermostats, a couple radiator pull and cleans, several carrier bearings within 30k of each other started around 180k but since then all has been good with it, two fuel sending units. This list does not include the stuff I have done to it over the years to make it "better".
2001 4X4 long box 6 speed 197,000 miles and running strong. Purchased used with 106,000 miles. To date no major repair been needed. I purchased a FASS fuel pump and installed right after purchase of pickup, also K&N air filter, Solid Steel Track bar and steering box stabilizer. New A/C pump and Brakes besides service every 3,000 miles is all I've done!
Well all good things got to come to an end, 200k rebuilt trans (Standard Transmission-Tuscon) new South Bend clutch, new transfer case input shaft, new ball joints and axle seals "front end".
Will it go another 200K?
270405 still running original vp44-looks and runs better than new as have done many upgrades -lived 10 years full time in 5th wheel never let us down--best truck I have ever owned-
truck sits in garage most of the time now as sold 5th wheel and went back to house. With much regret will be selling truck soon as to old to safely haul big rig.
2001 HO 6spd 2500. Currently 163,433. White and Grey two tone. I have owned my truck for a couple years now. They are an amazing truck for sure. I found used at a Dodge dealer listed on Craigs list, fresh trade in. Super clean old fart truck. I changed my cloth interior out with my 1998 Dodge 3500 4x4 V10 with orig 35,000 mi. Now its all Leather grey. Sold the V10. I loved it but man it was bad on fuel. When I bought the 2001 it was totally stock truck. Never touch or messed with. I pull a fifth wheel RV. Love this truck. I have upgraded the following.
Firestone Rear Airbags and on board compressor.
Airdog lift pump.
Stock and I think the original VP44. Runs great. Over 22 mpg at 65 mph empty.
Full gauges.
Ball Joints.
Brakes.
Shocks.
1 1/2 lift front. Just enough to level sag in front.
4 inch exhaust.
Boost fooler.
Rear back up fog lights.
Serviced rear diff.
Serviced Transmission.
Replaced passenger door, rust at bottom. Have the other rust free doors waiting when needed. No other rust found yet.
More to come.
Good to see a few of us getting the long haul from the VP44, 267K on my original VP44 and no signs of stopping yet...
Just found a small crack in dash, that sucks, it still looks new, going to try some gray epoxy to hopeful keep it from running! Other than that cosmetically still looking pretty good other than the black trim fading, think I will try one of the "back to black" products soon.
At the price of new rigs, I think I will be driving this old reliable truck until it isn't cost effective, LOL
SHG
2002 2500 4x4 HO 6SPD stock truck with exception of exhaust brake
228,000 miles (original owner)
VP44 at 87,000 miles covered by warranty
one starter contact kit - 150,000
one alternator bearing and brush kit - 215,000 (no failure, just maintenance)
front brake pads and rotors - 215,000 (still had 50,000 miles or more left, thanks to manual transmission and exhaust brake)
I just recently replaced ball joints, steering box, PS pump, vacuum pump, steering shaft, and added a steering box brace, and a fluid damper - all to give the truck a second life.
The truck has been very reliable and I expect it will continue to be so.
John
1999 2500 with 277,000 original owner miles
No engine problems with original Injection pump and injectors
Added FASS at 110k after replacing 4 lift pumps
5 spd trans replaced at 150k, then again at 270k.
Replaced power steering gear, shaft, pump and hoses at 275K, no more leaks
I just turned 115k the other day. One IP and two LP's. Replaced that with a fass a couple of years ago. Oh, and added a 4" exhaust system a couple of years ago when the oem just fell off. Other than that, no problems. I always have people coming up to me asking about the truck and making the "nice truck" comments.
152K so far. Told my wife to bury me in it.
Another day in paradise.
483k bought truck with 460k on chassis and 20k on trans and cummins overhaul, previous owner was a traveling salesman. Put an edge cts2 tuner on it right after purchase and, a fass system on it as soon as it came in, stock lift pump would bottom out at 1-2psi on stock power levels. Other than that just u-joint and a 4wd actuator, stupid factory unit seized and left me stuck in my driveway :(
Gotta say this is the best truck I've ever owned!!!
