how much p.s.i. should i run to a pair of air horns?
wet okole
Getting New Speaker Wire Into The Doors??
hi , just got 2 pair of air horns (24" grovers& 24" internatoinal harvester ) & a air tank & a. r. b. type compresser. how much air should i give them suckers to make them as loud as possable. also any body got any feed back on using all four. thanks, any help will be really apreciated. carl
Air Horns
90-120... . They really "talk" at 120! You may wanna call Grover to verify just for your own peace of mind. Hollar back if you need the phone number. Ron:)
The POS model #1167 compressor that Grover Products sells with their installation kits cuts in at 80 psi & cuts out at 100 psi.
thanks to all that replied so far. question i have now is, if i run the largest diameter line will i be able to get the solonoidof same dia. ? what ive seen a while back was some plastic line to accomadate the lanyard. anybody done an instalation from scratch?and remember the stuff needed.
mine is a scratch instail but I used a foot valve :D , I was going too go lanyard but I didn't like the one that was availiable not that there arn't ones out there that I might like & change too later
where on the island are ya, ( yea I'm from Brooklyn :p )
I'm only 15 min. from the PJ ferry
we could do this in one night or on a saterday
