How often should power steering fluid be changed?
Headlights not working
Help!
Don't understand why the turkey baster isn't working for you guys, works fine for me. If you want a super-duper suction gun guaranteed to suck your PS reservoir or master cylinder out in less than 2 seconds build your own. Just duct tape the hose of your vacuum cleaner to the top of a 2 liter pop container, poke a hole in it near the top and insert whatever size tubing you like, make sure it fits tight and goes to the bottom of the jug. You're ready to suck, just make sure the container stays upright so the fluid doesn't go into the vac. Use a stronger jug if using a shop vac so it doesn't collapse, the type that cranberry juice comes in works great.
