Hey Guys,
I'm buying a Case 580B hoe and have a couple of questions about hauling the thing. This would only be occasional, and non-commercial farm/personal use. The weight on the hoe's vary depending on the options, but the machine itself should be somewhere betweek 9,000 and 13,000 lbs.
I have a 2004 2500 which has a GVWR of 9000 and tires rated at 3,195. Front GAWR is 5,200 and rear is 6,000. Safety hardware such as trailer brakes, adequate class hitch, tire ratings, axle ratings, etc aside in this conversation, my question is in regards only to safe weight distribution.
The truck with me and random crap in it weighed in on the scrap metal scale a while back at around 8,500 lbs. I have the Kore DRC Race suspension, Road Armor front & rear, Transfer Flow, winch, line-x, some aftermarket audio, and so on that bring the weight up. So, if I eliminate some random stuff, I can probably get the weight down to about 8,000.
Here's the truck: (I swear there's a boat trailer behind it... )
Unless I go on a diet, that leaves me with 1,000lb to work with for a pin or tongue weight. I'm looking at some different trailer types and am trying to determine if there's a safe combination of axle position / hitch weight that I can get to and be able to haul this thing. The GCWR is no concern because it will be under 26k lbs, and I will only be transporting this in Arkansas.
Is there a type of gooseneck, bulldog, or pintle trailer that I can distribute the weight of this hoe to where there is only a half ton on the truck itself? The truck is heavy, and very stable with the suspension and shocks I have. I'm sure axle position will play a roll as well.
What do you gents think the best way to accomplish this is?
Thanks!
Patriot_RAM
Thanks!
Patriot_RAM
