I too had to learn the new torque curve when I 1st installed my turbo. After installing mine,I had all these big expectations and tromped on the go pedal,only to be disappointed. The factory turbo actually had more low-end cooling and driving habits needed to change quick to reduce the egt. I complained and argued with tech consultant and explained my dillemna to them and even talked it over with the experts here on TDR. The end result,after a test drive to prove their point,was that I needed to run a little higher rpm than I was used to. It takes a very hot day and a challenging grade to make mine go above 1250* with the R's around 2400. Do not be afraid to cruise at 2000 to 2100 or even 2200 to maintain speed on less challenging grades either. My truck has 3. 55's and with the convertor locked,I cruise at 1600rpm at 60mph. I usually try to maintain 65mph to get the R's around 1750 or better yet 1800 but sometimes it is just not possible,so I just the lock the OD out and lock my convertor to cruise at 50 or 55mph... . rpm is back where I want it. Driving this way,upon the recommendation of fellow TDR members,I have had no more problems and can appreciate the new power curve after re-learning how to use it.
I think the biggest issue I had was that in my mindset,I felt that if I have to downshift,then I am down on power. Not so..... you have much more power,just a different powerband. Find your new power curve and don't be afraid to let the rpm's go up a bit to reach it. Better mpg too... . but for me it was only 1mpg better though!
Alan
