Matt400 said:
I can understand your thoughts of the overlap being a source of restriction but flow and pressure are two different things as flow relates to volume and not pressure.
If you were to squeeze off the exhaust system you would reduce the volume/flow of air which in turn would raise boost pressure.
Same a squeezing off a garden hose, flow is decreased but pressure goes up as the hose gets hard.
In order to have pressure present there must be a restriction and reducing the restriction can only lower the pressure.
Close but you're missing several key issues, thus you're thoughts above are incorrect.
If you pinch off a garden hose, yes the pressure will rise and flow will reduce to zero, thus stopping your turbo from spinning, right? Without spinning you make no boost. Yes the exhaust pressure will go up but again, flow is reduced thereby not creating boost on the intake side.
Hard to prove (if not impossible) that higher restriction in the exhaust and slowing down the turbo will increase boost (it doesn't). The exhaust cycle and the intake cycle are almost completely separate events (other than slight blow down during overlap). Higher exhaust pressure will not make higher intake pressure (turbo not spinning, turbo not making intake boost, remember?)
If the turbo is restricted, it can't flow, if it can't flow, it cannot produce boost. If your theory was actually correct, then a completely blocked exhaust would make mega amounts of boost, but if the turbo is stalled, it does nothing, thereby no boost is produced.
Call a few turbo companies, they will tell you the same thing. On one big block we took off the restrictive manifolds, made custom headers to the turbos and picked up a lot of boost and lowered exhaust pressure a ton as well. Its the difference between intake pressure and exhaust pressure that moves the air into the cylinder. And that is due to having the exhaust flow without restriction.
Now for a supercharged motor, you are correct, since the SC is independent of the intake and exhaust cycles. Reducing the exhaust restriction will lower boost on the intake side due to the overlap period and having intake blow through the exhaust port more easily. Tubos and SC units are way different in the way they operate.
