2nd Gen Non-Engine/Transmission hub tool
Engine/Transmission (1998.5 - 2002) Which DDP's for towing?
2nd Gen Non-Engine/Transmission Track Bar Question
Are you looking at the front or rear?
The front hubs have an intrigal bearing, the outer bearing race is part of the hub assembly and not replaceable from what I have seen. The rears you can lookup the bearings on NAPAOnline.com.
Kevin
the reason i need to know the outside diameter is i am going get Posi Lock Puller but need to know witch one size im doing the front
