I've read several nightmare stories posted by guys who've had AC problems that started with a "musty" smell, and ended up with the removal/replacement of the evaporator coil, which is expensive as hell, and a very time consuming, labor intensive job.
I wonder if there would be a way to periodically introduce an aerosol cleaning solution into the dash, air returns, and maintain a relatively clean, efficient coil in the process?
There are all sorts of specialty cleaning solutions available in aerosol form; there's even one designed to be sprayed on chandeliers, which removes the dirt, and dries residue-free.
Everyone who's sprayed "contact cleaner" on a balky TPS knows what I'm talking about.
I've read several threads which mention the difficulty of removing the evaporator coil, either to clean or replace it, and I wonder if a far easier remedy might be effective—particularly if done as a form of routine, scheduled maintenance.
What I had in mind was turning the AC on, blocking the dash, return-air vents—except for the one that's directly over the evaporator coil—setting the fan speed on "high," and gradually spraying into the remaining return vent a can of evaporative cleaner.
I figure, "It couldn't hurt," because my AC performance has deteriorated noticeably; recharging the system doesn't help, and I, too, am beginning to smell that tell-tale mustiness.
Anybody have any thoughts?
