I can't find the screws I am looking for.
2004 Seat Replacement Time
Windshield Wiper Woes.
gpintler
I am currently finding and installing the options that I would have ordered, if I had ordered the truck .
2004 quad cab 8 ft box auto 4X4
I found the transfer case skid plate and the cross brace. The brace goes from outside of the frame to the outside of the frame. It uses 4 bolts that have tapered points and look like they are self-threading.
Anybody know what the part number is for that bolt ?
We used that style of bolts in some assembly applications. If they are the style, I think they, are they are not self-tapping instead they are designed for use with air assembly tools on the assembly line. The bolts should screw into weld nuts or threaded weld blocks on the frame. The assembler does not need to preassemble the bolts instead they just put the bolt into the fastening hole with the tool and start the assembly process. The bolt will self-locate into the threads without cross threading. At least that is the theory behind the use of that style of bolt.
